Interchangeability
surfdwn1969
I have a Mercruiser 233 with a Ford 351. It needs to be replaced. I know of a couple of decent Alpha 1 drives that are available that were hooked up with Chevy 305's.
How compatible are these outdrives? What would I need to do to swap these outdrives with mine?
Re: Interchangeability
They should bolt right on,+ Go........
wire2
I have a Mercruiser 233 with a Ford 351. It needs to be replaced....
What needs to be replaced? The Ford 351? Or the outdrive only? Both?
If you're switching the 351 for a 305, I believe you'll have bellhousing bolt pattern issues.
surfdwn1969
Just the outdrive needs to be replaced. The engine is in superb condition.
