Intake manifold verification
Jakem
Good day. Just want to verify this intake for my ford 302. I'm installing a new edelbrock 600cfm marine carb. Does this intake work before I order it. Or do I need marine intake if there is a difference. I have closed cooling system if that makes a difference
alldodge
You need a marine intake but could get by if in fresh water (for many years) or if closed cool. If in salt there is no way
Jakem
Mostly salt water...I do have closed cooling
alldodge
Then should be no problem.
What ya run into is just finding something for a 302, but with closed cool it can be treated like a car
with a heat exchanger, you can run an automotive intake.
also, run a 160F thermostat vs a 160.
make sure to paint the intake after installation to prevent corrosion.
Jakem
Finally got the intake...edelbrock 2121...I also ordered the intake gaskets and the ones sent look odd...7220. Any input
Jakem
I put one on head to see...no good
Jakem
Here's pictures...first are the ones I got with the order...second ones I bought today
