Some old guy
Thread starter- Joined
- Aug 1, 2006
- 3
Hi, I;m a new (used) boat owner and have an 18' Hurricane deck boat (9 years young). When I took the boat out of storage this spring, I hadn't realized the batteries were NOT maintenance free and ALL the cells were completely dry. I tried putting new acid in them and recharging them, didn't work so I bought 3 new batteries (1 for cranking and 2 more (hooked together) for the other things like horn, bilge pump, nav and anc lights, live well, dock lights, interior lights, radio/cassette,etc) I cannot get any of these things to work. Befors Iput the 2 batteries that are hooked together in, these things worked occassionally (i.e. radio would come on but if I pressed thehorn button, horn wouldn't work and radio would go off......things lkike that).
I put the 2 new batteries in and NOTHING works...no bilge, horn, radio, etc. I have checked all the fuses I can find which are back by the battery, put an ohm meter on them to check for continuity and that seems ok.....I have 12 volts measured on each of my batteries (which I have another question about),but I have no voltage at all on the switches behind the instrument panel.
My question is: Is there 1 big master fuse under the dash I should belooking for that might be blown ar are there other things to check?????
Battery question: When I hook the 2 batteries together, (they were like this when I bought the boat) there is a cable from #2 pos to #3 pos but no cable from #2 neg to #3 neg......should there be?
Thanks for reading the entire story!!!!!!
