Instrument panel
Realgun
<br />Just thought you might want a peak and I will have to make another 1 as I got the guages a wee bit tight on the left side.
Mark42
Re: Instrument panel
Hey Bud,<br /><br />I see what you mean. How big a space do you have to mount them? The reason I ask is because they will look best if spacing around and between guages is proportional to the space available to mount them. <br /><br />I remember cutting out round paper guages and taping them to dash before marking and cutting the holes in my boat. Because my dash does not have much height, I had to space the larger tach & speedo a little farther apart then I wanted to. I tried to make the space around the small temp guage equal between it and the bottom of the dash, and between it and the other guages. <br /><br />I think the placement of the guages on my dash came out nicely balanced, although the temp might look a bit crowded. I must have spent the better part of an evening moving those paper guages around the dash until I found a layout that both looks nice and is functional.
Realgun
Basically the dash that is show is what I got to work with. :) 5.25"x17" and thats it. I love to waste Plywood, you should see the scrap pile!<br /><br />In the now proto type the speed and tach are nice but the fuel and trim are wrong. The trim is not functional, yet. :D <br /><br />Hmm on second though I will remove the trim guage for now. Off to build a new dash. :)
Trim Gauge..!!.?? You Don't Need No Stinking Trim Gauge...............<br /><br />Real Boaters use the Seat of Their Pants to Know which way the drive is Pointed............... :D
Realgun
Bondo I got that guage for 14 bucks dirrect from Faria. How was I to relly know you have to have a sender. :) Besides If and this will happen 1 day, I repower I can use it.<br /><br />Now I want to cover the dash panel with a grey colored something what can I use other than vinyl?<br />I really dont want it shiny.
Primer,+ Paint....??......Flat or Satin finish......
lenny2113
I did my gauge panel from wood veneer/formica.<br />Came out beautiful. I used "cherry wood" color, cut out holes based on the pattern of the original dash which was a faded badly. New dash lasted for 2 years without signs of getting water saturated, then I sold the boat. But it looks great and the color variation is unlimited.
Boomyal
Like Lenny says, use a piece of gray formica. Maybe you can find a production shop where you can get a small scrap. Epoxy it on your plywood then go retrieve your rocks :D to set on it till it cures.
Realgun
Boom it seems the rocks in my garden grow the old rocks are to heavy to lift will need to get the babies out. :D
