Instructions for 2HP Evinrude 1985 or close.
jackhartjr
Hi folks, wonder where one might find the instruction manual for this motor.
I have the big manuals that cover the maintenance, just not stuff like how to crank it, fuel tank capacity, etc.
Thanks
Jack
Vic.S
Re: Instructions for 2HP Evinrude 1985 or close.
You should be able to get a a copy of the owners manual from KEN COOK ... at a price :(
The fuel tank capacity is 0.9 litres.
Fuel mix is 50:1, even if the decals say 100:1
To start put fuel in tank, open tank vent, open fuel tap, allow long enough for the fuel to fill the carb bowl, fully close the choke, open the throttle a bit (experiment to find best position) and pull starter.
As it warms up push the choke knob back in.
If the high speed and idle mixture needles are correctly set then the adjustment knobs should be set to the mid point of their adjustment ranges.
