scrampbell
- Feb 25, 2009
- 108
I have a 6 post key switch with push-in choke that I suspect to be bad so I'm replacing it.
The new key switch I have on hand is also a 6 post with push-in choke but the posts are labeled differently on the new switch so I want to make sure that I install it correctly.
The old switch had these posts in order... S-C-A-M-B-M
The new switch has this order... S-C-B-M-I-M
Should the wire(s) connected to "B" from the old switch go to "B" on the new switch? Or should the wire(s) connected to "B" on the old switch go to "I" on the new switch?
Thanks for the help!
