Installing Power trim
john purdy
Hi All, I have a 1975 Evinrude 115 an I want to put a power trim unit on it what years will fit? The motor model num. is 115593B serial num. J0006227, any input would be helpful. Thanks John
crb478
Re: Installing Power trim
It is an add on kit for 73-77 johnsons and evinrudes. It is no longer available from the dealer and hard to find used. The easiest thing to do would be to add a CMC tilt and trim unit.
tashasdaddy
CNC unit is going to cost, $600. add weight to stern. you might be better, selling what you have and buying a motor with trim n tilt.
