installing pivot screw
damlake
To start with I am an automobile mechanic, so I don't read instructions until it's too late.I took apart a 1975 Johnson 6hp to install a h2o pump(I found out it didn't need it after all,but thats another story)I mistakenly took out what my manual calls a pivot screw.This screw is in the lower gearcase and only has threads by the head.I am assuming it must be a line-up pin for something.Anyway I cannot get it to seat properly ,all the way in.I would have no problem removing the lower case if that is what needs to be done,Help would be apprciated.
Paul Moir
Re: installing pivot screw
If you don't mind fiddling with it for a bit, you can get it back in without disassembling the LU. What your trying to do is line up the screw hole with a drilled hole in a peice of bent sheet (the 'shift yoke') that connects the shift rod to the shift dog. So there's no precise aligning you have to do. You can move the shift yoke around a bit by manipulating the shift handle (or shift rod if the lu is still off). With this and an ice pick (or similair), you can get the yoke hole lined up enough to go through it, and into the boss on the other side.<br />My manual suggests grinding off the shoulder on the screw end a bit to help it 'self align.' I find it's not really necessary though.
