tubenewb
- Aug 10, 2010
- 86
Here is my new motor mount . Pretty much copied what came out of the boat originaly .
its a 2" rough cut PL'ed with a piece of 3/4" ext ..
Originally it was glued in at the outer corners to the hull with what appeared to me to be some type of blue bondo or filler...
Then the top side was covered in csm and roven woven tabbed to the bulkhead and deck...
There wasnt much of anything covering the rest of the mount fromn the elements..
The entire bottom side was exposed.
Here are my questions..
1. Is it a bad idea to wrap this things in csm before it gets bonded to the hull??
2. What was the blue filler?? Marine filler?? Should I use the same, or should I use peanut butter??
Thanks so much
Thanks so much
