Is there any special trick to help you line up the water tube seal on the water tube as you push the lower unit into place? I changed out my water pump and I'm confident that it's working but when I re-mount the lower unit, I think the water tube seal is slipping off to the side of the water tube, so it's not peeing out the tell tale.
I can't seem to get a visual on the alignment and still be able to push the lower unit up into place at the same time.
Any tricks or advice would be greatly appreciated!
Thank you!
-Dax
Thank you!
-Dax
