Installing Impeller, what lube?
mippel
I will be replacing a impeller soon, and I have read that there is a lubricant that you use when installing the new impeller. What lube is best used for this? The new impeller did not come with any lube. Thanks in advance.
Don S
Re: Installing Impeller, what lube?
Dish liquid.
Don't use grease, some types of grease and oil can damage the impeller.
mippel
Dish liquid.
Thanks, that is what i will use. Is that just to help getting it in the housing, and protect it until the water get to it?
Don S
More for ease of assembly. They dry up after use when sitting in your driveway.
