Installing Bearing Housing Seal Assembly
Hulkrage
Hello ,
I have a 1973 Evinrude 85 hp 85393M . I just pulled out the 0384523 - Bearing Housing Seal Assembly to change the oil seals . When I put the assembly back in do I have to use some kind of special sealant around the assembly to prevent water linking in or does the O-ring do all the work .
Thank you ahead for any help!
bob johnson
funny..... i just did my 1997 150 hp...... the book said the apply triple guard grease to the o ring and install, then later when the housing was going into the LU gear case they said to put a sealant on the surfaces around the o-ring!!!!!!!!!! ( I HAD TO CAREFULLY CLEAN UP THE GREASE!!!!!! but the design MIGHT be significantly different.... so I may be of no help!
jimmbo
Sealant or grease, it doesn't really matter. It's just to keep the o-ring sliding smoothly along the housing. The O-ring is what does the sealing
F_R
Honorary Supreme Mariner
I seem to remember the factory used a generous application of OMC Gasket Sealant. It's true that the o-ring is the item that does the sealing. The sealant just takes care of any minor imperfections in the surfaces. It also might help keep the water away from the area, which might cause corrosion over time.
Hulkrage
Thanks everyone !! Asking on her is more effective then Googleing for hours and coming up empty handed .
Happy boating
