Installing a Carb
papajoe74
Installing a reman carb on 4.3l mercrusier. Any problems I should be aware of?Suggestions will be appreciated.
180shabah
Re: Installing a Carb
Pretty straight forward, all the specs are in the manual.
Mkos1980
When you take off the old one be sure to look at all the linkage and the return spring so your familier with it when you reinstall. Also if removing old one, dont tip it too much as gas may come back all over you or the engine. Other then that, ditto to the "pretty straight forward" quote above.
PS Be sure to use a new carb to manifold gasket with NO sealant.
danond
Take cell phone pictures of both sides so you know what goes where. Nothing more frustrating than ending up with extra parts or stuff that doesn't seem to fit.
papajoe74
Thanks for all your help. I'll be doing it tomorow.
