Installed new battery and now gauges do not work...
GoHogs
I installed a new battery and now my gauges or my switches or lights do not work. I assume that I have a blown fuse or fuses, but I can't find the fuse box/panel to check. I have a 1992 Harris pontoon boat. Thanks for any help that you may have.:confused:
jamiemac74
Re: Installed new battery and now gauges do not work...
Make sure you have all the wires hooked up on the battery. Sometimes they will have a separate battery lead for stuff like that... Just a idea, I could be wrong in this case...
Ob1415
Or perhaps your switches have breakers on them? If so, there should be reset buttons for them, usually on the panel where the switches are located. Just a thought. Good luck.
Fireman431
More than likely you left off a power wire (12v+) that feeds the dash. Check around & under the battery for a red wire with a terminal end that isn't hooked up.
