install tachometer teleflex
dennis hackler
look at all the forum and found some to help but wasn,t sure if it might mess up something electrical. I have an 1987 mariner 45hp electric start and would appriciate any help with this matter.
marty53
Re: install tachometer teleflex
Your control box should have a connector in the front that you can either buy a harness for to connect to your new tach, or you can do what I did and crimp little female end plugs onto a set of wires and plug them into the purple, gray and black pins on the connector on the control box. easy and cheap.
dennis hackler
Thanks for the info and we will give it a try and thanks again.
