alpineswampman
- Jun 18, 2001
- 9
I have a 120 Evinrude and think I am having a fuel problem. Should the inline glass fuel filter stay full of gas while running wide open? Mine pumps up when I squeeze the ball but when I run wide open it empties out and you can see the fuel pulsing in when the fuel pump draws it in. The motor runs fine at WOT but if i drop to 4500 rpm it runs for a minute and then seems to be running out of gas. If i open it back up, it hesitates and then starts to run fine again. It idles fine too.<br /><br />I have changed the fuel filter, primer ball and fuel hose all the way to the tank to the motor. I am thinking it may be a bad fuel pump or inside of the fuel tank. The vent on side of the boat is not blocked. Would an anti-siphon valve cause this? <br /><br />Any ideas?
