inline 6 150hp plugs?
sourbsted
How often would you expect to have to replace the spark plugs? My boat still don't want to plane,timing perfect, carbs serviced. The plgs are about 4 years old. Not much use though but a lot tuning problems lately.
Mi duckdown
Re: inline 6 150hp plugs?
Spark plugs rarely go bad. I would look elsewhere. How is your compression? Linc and sinc?
sourbsted
Set at BTDC 2 degrees, compression 140-150. Im thinking lower engine crank seal. Something major has be to wrong. Will eventrially plane if I keep trying...
sourbsted
Will now take it to someone, this motor is rooted.
Chris1956
Not sure what "rooted" means. If the lower spark plugs look like new, water may be gettig into motor via lower crank seal and steam-cleaning the spark plugs. If not, check plug wires for arcing, and check them for resistance. Resistance should be zero....
What kind of boat is that motor on? What is pitch of prop?
mercurymang
Master Chief Petty Officer
Plus what RPM are you running when trying to get on plane. Are you sure you boat is not water logged?
Moody Blue
More info would help. What does the above mean?
Can you describe in more detail how the motor runs?
Carbs "serviced" is vague. What was done to the carbs?
sourbsted
The boat is a Aussie built "savage escort" 16ft runabout. The prop pitch is P19. Top speed 40-43 mph , have no tacho, used GPS to check spd.
Carbs have got new needle& seats, floats-float level set. New fuel lines to carbs. Fuel pumpbeen kitted.
Primary pickup plate hits throttle arm at BTDC 2 degrees.
Idle mixtures set at 1.5 turns.(strting point)
New timing belt, spark plugs.
The boat struggles to plane, hesitates, won't increase speed. If I much around with the idle mixtures It will eventrially plane, but struggles.
I Did learn today that the cheapo bulb Is allowing air into the fuel line! That cant be good! I want to buy a quicksilver one now. [IMhttp://i304
CharlieB
Idle mixture may still be too lean, limiting power and making it difficult to plane. Once on plane the motor is off the idle circuit, on the main jet and runs fine.
Idle mixture must be adjusted with the boat IN the water to provide the correct exhaust back-pressure, and IN Forward gear to place load on the motor.
1 1/2 turn out from lightly seated is an initial setting to provide enough fuel to start the motor and get it into gear, from here you need to adjust each carb idle screw to "Best Idle Speed" while IN Forward gear turn one idle screw out in 1/8 turn increments or less and give the motor a minute to respond and burn off any fuel accumulated in that cyl.
LISTEN to the motor, you want to adjust to 'Best Speed' it can take a while to get to that 'Best' adjustment, finish one carb before proceeding to the next. Once finished with all carbs go back to the first carb and repeat the adjustment to be sure you have it perfected.
Now the important part
Once at 'Best Idle Speed' in gear, the motor needs additional idle fuel for crisp acceleration.
Turn each idle screw out 1/8 turn and test acceleration. Any hesitation, bog, lean cough or miss indicates a need for additional idle fuel, turn each screw out just the width of the screwdriver blade slot and repeat acceleration test.
Repeat to perfection.
Verify that you have sealed all air leaks in the fuel system.
Test by temporarily installing a clear hose between the fuel pump and carbs, run the motor and watch for any air bubbles passing thru.
Air leaking in will cause the upper carb to run low on fuel, leaning that cyl, raising combustion temp and toasting that piston.
Remember to remove the clear hose once finished with repairs.
Clear hose is not approved and is not recommended for fuel use, only as a short term testing tool.
sourbsted
Good information their Charlie, thanks,very easy to understand. I can't beleave a boat place charged me $30 for a bulb& line that leaks air into the system. My little 15hp mariner didn't even want to run properly on my last water test. Died under load, they both feed of the same line,i just switch them over when ever I need to.
Cheers
Chris1956
Ok, Run her at WOT for a while and then with as short an idle time as possible, check the color of the spark plugs. Try to go from WOT to motor stopped very rapidly, to check the color of the spark plugs. All spark plugs should be a light to dark brown, and all about the same color. White, green, black or real clean spark plugs are a bad sign.
Moody Blue
How about the fuel pump? Could be yours is aged and not operating at peak performance, thus not supplying enough fuel at higher RPM.
The rebuild kits are cheap and easy to install. Might be worth the time to do.
sourbsted
I bought a full gasket kit off eBay, I was stoked on how much it had in it. I was gobsmacked over the condition of the pumps, they were rooted. They worked ok still, the diaframs were stretched..
Cheers..
Moody Blue
OK I had to look up "rooted". Now I understand :)
(Australia, New Zealand, slang) Broken, damaged, non-functional.
I'm going to have to call a mechanic, my car's rooted.
sourbsted
I couldn't help myself, when Chris didn't know what I meant by the word "rooted" I had to make another post with more "Aussie slang" in it. People say we use a lot unusual word. LOL. I get irriated over words "down under" :)
buzzm19
16' boat, 150l6 motor 19p prop, that combo should jump out of the water on the gate shot. Buz
