D_Wilson
- Jul 29, 2004
- 39
My wife and I have the good fortune to have just bought some property on a beautiful lake in Ontario. I inherited an old Evinrude 6hp Fisherman that had been hanging for at least ten years in a basement. The serial# is 6602E-E04323. It would not run at first so I took the carb off and found the needle lacquered shut. I blew it loose, cleaned all., reassembeled and it started right up. Now I'm having some big issues with power and such. It often sputters, idles rough, and I'm sure it's not reaching it's full RPM. It runs better at half choke. I'm learning a lot from reading these forums. I plan on replacing the impeller ASAP (it's spitting a good sputter but not a stream), and also the points and condensors. My problem is simple. I don't know what year this is so I'm not sure of what parts to by. I'm assuming it's a 50:1 fuel mixture also but I'm not positive. If anyone can point me in the right direction as a year I'd appreciate it. I'd like to get this motor running top notch to push my new 14" Lund around the lake. Thank you in advance.<br />D Wilson
