Ingnition switch help needed (Merc 115hp)
Scott75
First time posting but long time lurking...
I recently had to replace my ignition switch because it was falling to peices. I ordered a Seadog Line 420383(-1) from Iboats and im having some troubles getting it wired in and working. I was hopeing one of you guys may be able to help me out...
Here's the switch wires:
Yel/Black - Choke (connects to Grey wire on cable)
Black - Magneto Gound (unsure where to connect)
Black/Yel - Magneto Circuit (unsure where to connect)
Purple - Ignition Circuit (unsure where to connect)
Yel/Red - Starter Solenoid (connects to Yellow wiire on cable)
Red - +12v (connects to Red wire on cable)
Here's the cable wires that goes to the motor:
Red - +12v
Black - -12v
Grey - Choke
Yellow - Starter Solenoid
Brown - Unsure
White - Unsure
Orange(maybe salmon) - Unsure
Its a Mercury 115hp motor on a 1985 17.5' Procraft.
NYBo
Re: Ingnition switch help needed (Merc 115hp)
Welcome to iboats!:cool:
The purple feeds the instruments.
The orange is probably the overheat alarm.
I would remove the motor cowl and see where the brown and white wires go. A service manual for your motor would help also.
Silvertip
Honorary Supreme Mariner
Not sure I understand the issue. Are you wondering what terminal on the switch each wire connects to? If that's the case, each terminal on the switch has a letter next to it. The are as follows"
C = choke
M = magneto ground
M = magneto (the magneto wires can be reversed on thise two terminals -- it makes no difference which goes where.
S = Starter solenoid
A = Accessory (this is the feed for the instruments (purple wire)
B = Battery (this is +12 volts from the battery via the engine harness -- red wire)
Scott75
C = choke
M = magneto ground
Yes, I'm tring to figure out which wire goes to what wire. There is no lettering on the paticular switch that I got. The wires coming out are all inline, but it did come with a diagram of what each wire is.
The problem I have is I dont know which wire to connect them to on the cable running to the motor. I have found what some of the wires on that cable go to, but not all. The brown, white, and orange ones are the ones I dont know where to connect on the switch. Where I posted "Here's the switch wires", that was taken from the diagram that came with the switch.
Perhaps I order a switch that wont work with my motor? I ask because you say the purple is for accessory and the diagram says ignition circuit.
Thanks for the help guys, please bear with me...
Silvertip
Does this help?
Scott75
Sorry for sounding so confusing...
Can you tell me what these wires going back to the motor go to?
Red - +12v
Black - -12v
Grey - Choke
Brown - ???
White - ???
Orange(maybe salmon) - ???
Silvertip
Since we have no idea what year your 115 engine is, wire colors may not be the same -- but here is what I have.
For any of these wires, remove the cover on the motor and look where the wires go that come out of the harness that runs between the control box up front and the engine.
RED is +12volts and is hot all the time. It probably comes from a junction (terminal block).
BLACK is ground. That wire would connect to any ground point on the engine (usually the engine block)
GREY: My information shows this as a Tan/Blue wire which runs to the choke solenoid or the primer solenoid depending on which system you. Look at the solenoid. Grey may be the Tach "sense" wire for your engine and it does NOT go to the ignition switch. It would go to the "S" terminal on a tachometer.
YELLOW: This wire goes to the small "start" terminal on the starter solenoid and in my info it shows a yellow/red wire.
BROWN: Again, there is no brown wire on the ignition switch. Tan (or brown as you may be calling it) is for the temp sender.
WHITE: No idea what this is for but it does not go to the ignition switch
ORANGE: No idea what this is for but it likely does not go to the ignition switch
You seem to be missing the magneto wires. These two are black and black/yellow.
If your engine is an older 115 then you need a wiring diagram for the motor.
Scott75
Sorry, its a 1979. I've chased down most of the wires but like you im still at a loss on the Tan and Orange wire. I took a pic of the engine to show you what the 2 wires are running to...1336990423847.jpg
Scott75
Untitled.jpgBased on your help Silvertip, here is what i have so far. Those "boxes" are based on the pic from the post above...
NYBo
You don't want to run accessories through the ignition switch. You hook the gauges to this terminal, like this:
Scott75
Got it running! :p my orange wire was the kill, black was to ground see updated pic...
@NYbo i just used sterio as an example...
Thank you NYBo and Silvertip!
I couldnt of done it without you guys!
