ingnition module/ camshaft auto vs. marine
trexmerc
i have a 97 four winns with 4.3 volvo. can i run the normal 4.3 ingnition module i.e. s-10? what is the differance? same qustion with cam shaft, except cam i will be using after market prod. no. on block is 3868661 model no. is 432bplkd.
Don S
Re: ingnition module/ camshaft auto vs. marine
Got rid of your duplicate post for you, moving this one over to the OMC forum. The 432bplkd number is OMC, not Volvo. The Volvo number would have been something like 4.3GLXXXXX
trexmerc
im confused the tag states volvo penta prod. mod. so forth so on
Don S
Would bet the serial number starts with a T correct? That is OMC.
OMC and Volvo were in a joint venture for several years. There was a Volvo version and an OMC version. Similar, but some differences also.
perna00
You can swap the automotive module with the marine one without a difference. It just triggers spark so their isn't any difference as far as performance. Just make sure the pinouts are the same.
The cam shaft you will have to get one with the same lift/duration on it. If you don't, you will throw off your powerband, fuel economy, and mix up the computer's ability to try and "tune" your engine.
trexmerc
thank you perna00 thats what i thought on module. just wasnt sure cause the avance is different. camshaft im still carbed so i should be good to step up to an rv cam?
Don S
Advance curves is what the difference is between modules. If the S10 has a different advance curve than the marine version, guess what, they are not the same.
I have no clue what the curve is or what the module number is for an S10, but if it's not the same as the marine version, then it's obviously not the same.
