Information on boat?
JoshOnt
I have a thundercraft v142 not sure the year. I can't find anything on the iboats specs page. The serial number is V14691. It looks like it is rated for 150 hp if I am correct (hard to read the plate). Anyone have information on this boat or know where I could find some?
southkogs
This kinda' sounds like one of your other threads ;)
I think your boat is pretty close to THIS one. You've gotta' be rated somewhere between 60HP and 90HP. I can't imagine a 14' boat rated for 150HP without being designed as a single seater race boat ...
... unless, of course, you're Frank Acampora. :D
JoshOnt
Yeah I know it is pretty much the same, was hoping someone that hadn't see the one before might know something other that what the larger model would have been.
jbcurt00
Josh, please try not to start multiple topics about the same aspect of your project, as Erik (southkogs) noted.
All you needed to do was pull up the 1st topic about the V142 and make a post in that topic to bring it back to the top of the most recent post list. Typically w/ a
bump
or
BTTT
Either one bumps/brings to the top your topic
It'll prevent someone that has viewed the 1st topic, but were unable to help, from opening and reading a 2nd topic they still won't be able to help w/
Keeps all the help and any info you've gotten about a subject in 1 place so anyone that comes along later can see where you started and were you've gotten so far.
Helps you keep tabs on whatever help and suggestions have already been made.
Reduces duplication of effort by you and those that are trying to help
If you wanted to re-title that V142 topic to Boat Info Help?, you just needed to ask a Mod to change it for you.
thanks
If you scroll to the bottom right column of this page you will see BOAT MANUFACTURERS (+250). Click on that link and then scroll to your boat manufacturer. There is a forum for all of the listed boats. ​
