Information for 1954 Johnson Seahorse.
Erics512
I just got a free 1954 seahorse 5.5 hp and from what I can tell it's been sitting for at least 5 years. I rebuilt the carb, new float gaskets and cleaned it out. I tried starting it and I can't even get it to sputter an I do have perfect spark and compression. I've never worked on a boat motor, so my questions about this motor are...
- what are the "factory" carb settings on the high and low speed needle settings ?
- how does the gas get from the carb to the plugs? Are there valves? Could they be seized? The plugs don't look to be getting fuel on them when I'm trying to start it. (Perfect blue spark on plugs)
- is there a kill switch on these motors? Or how do you stop it when I do get it running?
Any information is greatly appreciated Thank you
Joe Reeves
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
1 - There are 2 leaf (flipper) valves at the intake manifold area in back of the carburetor... piston goes up, valve is sucked open... piston comes down, valves are forced shut.
2 - Some engine have a Kill Button, some do not. The ones that do not... simply turn the throttle handle very low, it'll stop. If not, pull the choke out and flood it out.
NOTE........... DO NOT attempt to run the engine at full throttle in neutral OR even in gear if out of the water. That will invite a run away condition you do not want to encounter!
F_R
Honorary Supreme Mariner
Eric, many times somebody will comment that they don't think the motor is pulling gas because the plugs don't get wet. They should NOT be getting wet, that would indicate too much gas (flooding). Engines run on a narrow range of gas vapor to air mixture.
Also, I don't care if it has spark or not, at least remove the recoil starter and cover plate off the flywheel and look in there at the coils. If they are cracked, you are wasting your time until you replace them. ALL twin cylinder motors by OMC of that vintage have cracked coils unless they have already been replaced. Get new ones here at iboats.
Erics512
The coils look good, but where can I get new wires and could on this site? And what type of plugs should I use?
I guess my concern was the gas wast getting to the plugs at all... Like once it gets past the carburetor it just stops, but i don't see anything dripping out of the exhaust or anywhere else proving to be an overflow/flooding situation.
Thank you for your responses
