info on gamefisher 5hp
Buckshot69
Yall are the best guys in the world, thanks to you guys ive turned into the local "shadetree" outboard mechanic. Heres my queston, Gamefisher 5 hp. Model # 217 585461 Ser# 18 125442. What yr. is it and its got no spark, where to start? Thanks in advance!!
steelespike
Re: info on gamefisher 5hp
Motor is an 81 built by Eska.Uses a air cooled Tecumseh power head
with a water cooled exhaust leg. Electronic ignition parts are expensive and hard to find.You might try the usual cleanup and adjustments.RJ13Y champion plug set at .030.Certified parts corp may have parts.Also a small engine shop.I my opinion not worth a big investmentn in parts and time.
noisey,vibrate,underpowered,and require tinkering to keep in operation.
