Re: inflatable catamaran
Thanks for the ideas on the motor height adjuster. I can see that since my top bolt hole is not thru the transom top square tubing that my motor is too low as I had been suspecting.
great ideas for the tiller extension. I suppose it is all custom and did notice the leash to keeping from contacting the floor on a kick up.
I could offer my two mods I am not seeing.
First is an anti tourqe spring with a rope cam adjuster to trim out the tiller pressure.
Also, I believe I had suffered from fuel foaming so went to a fuel bladder. Rather than including it inside a rigid fuel cell I use the neoprene envelope alone and enjoy the added cockpit space, lack of sharp edges, apparent fuel level, able to move around then fasten to floor as needed for balance.
Although, I do seem to have a flooding problem on my lower carb and wonder if this bladder may be sending pressure spikes in rough landings.
