I bought the 4X8 flatbed trailer from Harbor Freight and it works perfect for my 14' inflatable. And you can trailer with the motor on the boat because the transom is fully supported. The only mods I made to the trailer was I lowered the fenders so they are flush with the rest of the bed and I covered them with white "cutting board" material. (Get the trailer with 8" wheels, not 12" wheels, if you want to do this.) The bolts are countersunk and the tubes sit directly on them. I put two 2X4 rails lengthwise on the outer edges of the plywood deck that act to keep the boat straight when loading and it works perfectly. I added eye bolts to the tongue end of the bed to support a transom bracket. That's it. I also replaced the lights with waterproof ones, but I did that as I was putting it together. I'm actually taking my boat down for the season tomorrow and I can take pictures of the trailer if you think you're interested.
Drowned Rate - I like your trailer setup and would like to duplicate it. In order to lower the 8" wheels do you need to drill additional holes in the frame? Does this limit the amount of wheel travel in the springs? Any other issues in lowering the wheels? Thanks very much.
Hi guys, LD is correct, you only need to lower the fenders which only involves drilling two new holes in the fender brackets. Just drill the new holes before you install them for the first time. I was tempted to just leave the fenders off, but thought road debris might spin up and hit the boat. I have driven this trailer all over the place. From Phoenix to Lake Powell, Grand Canyon, Lees Ferry, Lake Havasu. 80 mph and it tows perfectly, no drift or bounce at all. Tows straight and smooth. Only thing I've done to it in 5 years is replace the plywood deck with marine plywood and new tires. If you're thinking about doing this project, spring for the more expensive marine plywood right from the start. The original board I put on there was trashed after just one season.
Hey guys bumping this back alive. My questions are
1. Advantages of flat plywood deck vs bunk and rollers
2. 8" vs 12" wheels and other variables between the two trailers.
Seems like you could just put a boat like that in the back of a pickup. What are you towing with?
Don't know about the other guys, but my boat fully outfitted weighs about 800 pounds.
Sounds like about the same weight as my snowmobile - and that goes in the truck bed
