Increasing horsepower
Jim Eigner
My son purchased a 95 - 25 hp Evinrude, and I purchased a 94 - 30 hp Evinrude - we note in the owners manual that both have the same blocks, in fact the 20, 25, 30 and 35 models all appear to have the same displacement. Is it possible for us to convert our two outboards to 35 hp? If so what do we need in the way of parts and how do we do it? Any advice is greatly appreciated.
JB
Re: Increasing horsepower
It could be done, Jim, but like hotrodding a car it is very expensive and, in my opinion, not worth the trouble.<br /><br />OMC went to some trouble to not make the differences easily available to the public, and some of them are still not easy to identify.<br /><br />Compare the performance of the 20 and the 25 on-the-water. I think that you will agree that in real world performance the differences between engines of the same displacement is trivial unless you are into racing.<br /><br />Now someone will come along and contradict me, but you have my opinion, at least.<br /><br />Good luck. :)
Jim Eigner
Thanks JB for the insight. I have heard from a few folks that one only has to replace the carb and exhaust reeds (along with some gaskets); if it is that simple, it may give me a bit more power for pulling an inner tube. Currently I have some trouble in getting my 14 year old up on top of the water using a 10 x 15 prop.<br /><br />Jim
G DANE
Now I dont know about the 3 cyl looper you have, but on the 40 and 50 HP, major difference is in the reed stops ( not reeds ) and cylinderhead design. I changed cylinderhead on my 84 35 HP as it had a 20HP head on for some reason, and compression bumped from 125 to 135, but I have to second JB ( he knows his stuff !!! ) I gained no speed - or next to no. Look at a parts drawings, and check if reedstops arnt different. Change them if you like, easy and not too expensive, might give a little. BTW there are no exhaust reeds, only intake.
