Increased amount of Bilge Water
Washing Machine Charlie
I have a 1978 Invader Bow-rider with a 115HP Johnson Outboard - Seats 6 with an adjusted weight capacity of approx. 800lbs. I have been out 4 times this season with just 2 persons on board for about 2 hours of riding time. Each time there has been zero water out of my drain plug. This past weekend we had 4 people total (below our weight restriction) and were out for about 4 hours total. After pulling the drain plug a considerable amount of water drained from the boat. My guess is about 15 gallons. We distributed the weight evenly on board, however is was clear from the start that the boat was lower in the water. Does this sound reasonable? I now am considering to add a bilge pump for safety. My larger concern with an older boat is that there is a leak.
ajgraz
A couple things:
1) Did the extra 2 people sit toward the stern? It may be that the extra weight there allowed more water to splash over the transom, and then make it's way into the bilge, perhaps through a deck plate that isn't sealing well, etc.
EDIT: 1b) I suppose if they sat up front and extra water was taken over the bow, would be the same result.
2) Is there no bilge pump on the boat now?
you should have a bilge pump to begin with
you may have a leak. now to determine where its coming from. with additional weight in the boat, the boat sits lower, so you could have a transom bolt or something that normally is above water sitting lower. either way, you are going to need to find where its coming from.
southkogs
One time my bow eye got me ... I was loaded heavier than usual, and when we were just puttin' along the bow eye was submerged. Turns out it had unseated a little and was leakin' like crazy.
Assuming this is a rather new-to-you boat?
Thanks All. Answers to your questions:
The passengers were all in the center for most of the trip and if someone was in the stern someone was in the bow.
Yes this boat has no bilge pump which I thought was odd as well.
The boat is very new to me - recently purchased.
From your feedback I think the likely culprit is the either a transom bolt that was submerged or the bow eye, possibly both...
I will be installing a bilge pump.
charleso
That's a lot of water. I was getting some water in my bilge. Purchased a new drain plug. High and dry last time out. Less than $2 fix. And +1 on getting a bilge pump.
southkogs
With that much coming in, as mentioned before - make sure you find the leak. 15 gallons is a lot to take in.
Maclin
15 gallons is a lot, weight would be 120lb, an extra person. Are you sure there was no water, from rain or other, already in it when you went out? If there was then that could be a reason it sat a lot lower than you expected with just the 2 extra passengers. Another potential leak source is the joint between the hull and the cap at the rubrail. In rougher water, or if it just sat lower than the rubrail somewhere then water can come in that way.
Any leftover or unused livewells on that rig?
No rainwater as its been clear when out and boat is stored in my garage 24/7. No live wells either. From pretrip inspections and draining after each previous trip zero water has drained from the boat. I always pull the plug at the ramp when I retrieve in order to check the amount draining. So where ever this leak is it is significant.
Bayou Dave
With the boat on the trailer and drain plug in, run a hose in the bilge. Look for any place that water is escaping. Just don't fill it so far that it hits any electrical wires.
