gnarbrah
- Sep 20, 2007
- 140
So, as you may have read I am looking deperately for a repacement carb for my 1988 Johnson 20. I've been through every listing I can find on ebay and all over the web and nothing. I got to thinking after looking over the one I have.
Can I be looking at different years / horsepowers?
Next, I started looking at what my major problem is and I'm thnking it's just the float chamber really. The fitting on the front where the primer hose attaches is broken off and full of JB Weld. Then the high speed jet / orafice plug (?) behind it is completely trashed and I can't remove it. So my question becomes can I just get a new bowl? I think the upper half of the carb is salvageable.
If so what would be the correct part? On the one I have it is stamped "330503"
On OMC's website it lists 2 part numbers - "393130 and 393131" Trouble is they have identical descriptions but one is twice the cost of the other???
So I'm looking at 3 part numbers - what one do I need?
**Update**
As I contiinue looking at my problem I started noticing that the diagram on OMC's site looks quite different than what I have. I've attached pictures for reference. You can't really make out the number on the Float Chamber but it is 330503. Should this match the part numbers on OMC's site? Also, I tried to buy a new float cahmber off their website but I can't get anything to stay in my cart? Anybody else have this problem or is there a better place to buy these things?
**Update**
