Inboard Transmission
Jango
Does anyone out there know where I can purchase a Good Used or Remanf. Borg Warner (Velvet Drive) 71 Series, 1:1 ratio Transmission. Thanks in advance.
Trent
Re: Inboard Transmission
What's wrong with the one you have?
Jango
I don,t have one. I am building a new Boat and am looking for some parts.
Jango
Thanks Snapperbait, I'm checking in to it.
Jango
Missed the one on E-Bay - Still Looking
Jango
Thanks for the help everyone. Found a Model 71C, 1:1 on E bay. Don't have a cooler though. Can I use an air cooler,or something similar,used on a car or truck? The water cooler (pictures I've seen) seems quite small which suggests not much cooling is required?
mkast666
As far as the cooling issue, mine used a pumped sea water cooler, water temp is always low 40-65 degrees. An air type cooler, you would have to force air through the cooler, what about when you're in a no wake zone, not much air?<br />Just a thought.
Oil coolers, Water, Not air, are on ebay All the Time..... CHEAP..!!!<br />You'd be better off with a jury-rigged water/ oil cooler, than a air/ oil cooler.....<br />Merc. P/Steering coolers are easy to find,+ will no doubt be big enough....
snapperbait
Water/oil type coolers are smaller because they are more efficient.... If you think you might have fluid cooling issues with the 71-C, install a sensor and a warning buzzer or a temp gauge....
Jango
Thanks for the tips, I'll keep my eyes open for a water type cooler
