inboard general info
krisnowicki
Is there a good site where can I check out how striaght inboards work and how there transmissions work?
ken_23434
Re: inboard general info
In the ---Adults Only--- sticky is a link to the official Mercuiser Service manuals. The intro to each section (motor, electrical, etc) gives a description of the system and such.
But, the service manuals I mentioned mainly cover I/O engines. I think a few cover some of the old Mercruiser inboard transmissions. I think it might be Manual 1 - 3 that covered them. From what I know, Mercruiser hasn't made a straight inboard transmission in quite a while.
ken_23434
Manual # 1 section 6 covers the series 71 and 72 Direct Drive transmissions. I think these are the predecessors to the Velvet Drive Transmissions that are still fairly common.
krisnowicki
i pulled that one up and it was only 7 pages long am i doings something wrong?
ken_23434
Service Manual #1 1963- 1973 All Engines and drives
Link opens index only, you need to click on the section in the
index on the left side of the screen to access each section
http://www-alt.mercurymarine.com/mne...l/01/cover.pdf
Service Manual #2 1974 to 1977 All Engines and drives. (1.0GB)
http://www-alt.mercurymarine.com/mne...l/02/cover.pdf
As it says in the description, you need to click on each section once you open the main part and it will load the next section. If you save each one to disk in the same folder, then later, they will all work together.
But, manual #2 also has info on the direct drive and v-drive transmissions. So, since you are just looking to "study" that one might be easier since it is all one document. It's a long download, though.
ken_23434
Read it cover to cover... well see you again in a couple weeks. :D
