In-line Fuel Filter Placement
Jon Boat Jim
I have spliced in a small in-line fuel filter between the fuel pump and carb. on my 1983 7.5HP Evinrude. Is this an OK position?
The filter is a "see through" type. Gas does not fill the filter housing completely. When the primer bulb is pumped, gas partially fills the housing. I have tank tested the motor with this set-up and it appears to run fine......no problems at idle or high speed. Do you think that it's safe to take out on the lake?
kbait
Re: In-line Fuel Filter Placement
It should be fine. The air bubble will probably get pushed through in time w/no ill effects. I usually just replace the hose from pump to carb, as there's a screen in the pump cover to catch any crud, and the new line to carb shouldn't decay for decades..
Jon Boat Jim
kbait, thank you for the response.
I did use a new fuel line for the installation. The screen in the pump appeared to be very coarse and that is what prompted the installation of a finer filter. Your comments would be appreciated.
boobie
Don't worry if you don't see the filter filling up when running as it's perfectly normal. Go run it.
