johnnyrudeinator
Thread starter- Joined
- Sep 19, 2007
- 14
okay this will be kinda long...maybe should split it up. I have read that and been told the weak spots on the inlines are the cooling and fuel systems. This winter I'm going to rebuild carbs and fuel pump. will it hurt to go up to a larger diameter fuel line?? I have the two diaphram fuel pump set up...what about changing to the newer self contained pump?? which is better?? Anyone ever use a small carter or holley electric pump?? regulated that might be a good deal and give you a stead psi. Just a thought. What about the carbs?? just get a gasket rebuild or do I need to get new jets?? I will do the floats and needles. Also going to rebuild the water pump...lower piece all the way. I bought a new lower half off ebay off of a 75 and I forgot to check what the one on my new lower unit is....will they all work if you have the new base?? Can I just find the top and gasket impellor set that will go with my new base and it work?? she pees okay...but I would like to improve it..I know doing the pump will but can you do anything else to improve flow. I'll quit this one here and start another one. Thanks Alot for any imput!
