Impossible to pull out the bearing housing
salar600
Motor is a Rude 70hp 1977.
As I want to change oil seal, I tried to pull out the bearing housing with a puller but it doesn?t come out.
Is it possible to change seals with the housing in place?
What sould I do? Any suggestion?
Thanks, Martin
Chinewalker
Re: Impossible to pull out the bearing housing
You removed he four bolts holding it place, yes? If it a salty or otherwise corroded, it may be stubborn...
- Scott
salar600
:confused: I mist this one, tought they had to stay to bring everything out... now I feel stupid!
Thanks, Martin
bankerjohn
Gearcase diagram only shows 3 bolts ... is that correct?
salar600
Mine has 4 bolts.
Is Silicone gasket maker equivalent to OMC Gasket Sealing compound ?
Thanks, Martin
jonesg
"OMC Gasket Sealing compound "
aka gorilla snot.
