impeller
hex
Need help, i am installing small rubber impeller for 1980, 35hp johnson, i notice a groove on inside part. i am not sure witch is up or down. this part is located in the bottom end gear case. There is a number on part should i assume the writing is to go right way up instead of upside down.
