impeller stuck...need some advice
circlehook69
I'm in the middle of changing out the water pump on my '94 evinrude 48spl. The problem I'm having is that the impeller is not budging. I was going to let sit overnight with some PB sprayed on it and hope it will come off in the a.m. Anybody have some suggestions on how to get the old impeller off the shaft? :confused:
toddschubert
Re: impeller stuck...need some advice
hit it couterclockwise with a hammer and screwdriver and cross your toes. I had same prob on my 88spl I pryed and pryed and finally got it off then my parts guy tells me the above. would have saved me some aggravation
boobie
Don't you mean clockwise??
Xcusme
Hmmm...Don't you mean CLOCKWISE....!!
JDusza
Flip it over first!
Haffiman
The drive shaft normally rotates clock-wise. Lock the impeller with a wise grip - turn the drive shaft COUNTER clock-wise and it should come loose.
boobie
But if you hit it with a big screw driver and hammer you should hit it CLOCK-WISE.
toddschubert
Wise guys...just hit the freaking thing. Ya already got to replace it. Just don't damage shaft lol
circlehook69
Thanks guys. Got it after letting some PB sit on it over night, just a couple taps and she came right off. I have read about reverse flushing the system. Is that necesary, and if so, how do I go about it?
i read on another post that you can try to split the impeller with a sharp chisel and a hammer good luck!
HighTrim
While the gearcase is down, I remove the t stat and run compressed air, or the garden hose, up the water line, ensuring it exits at the t stat housing. Then back flush the compressed air or water from the t stat housing down.
Have seen many guys do a water pump, bolt her back up only to find out then that there is a restriction. Better to ensure there is not while the gearcase is down. Unless you like doing things twice. ;)
This is mainly when the impeller breaks apart and she overheats, but better safe than sorry.
