Bondo said when reinstalling you need to keep it from popping out of gear. If you dont keep counter clockwise pressure on the prop it will pop out of gear. You wont be able to mesh up shift mechanism or rotate the drive shaft to mesh with splines in coupler.Prop won’t be on the shaft at all during that time
IrrelevantProp won’t be on the shaft at all during that time
