Impeller replacement
ronjon27
I have a 2004 Johnson 4 stroke, 40 HSP, Serial number 17022468, Model: J40PL4ST. Before I put the pontoon in the water, I noticed that no water was coming out the cooling exit port. I suspected I needed a new impeller. I dropped the lower unit and saw that I had a hard cast impeller housing so all I needed was the impeller, ware plate and gaskets. I replaced all those and the project went smoothly. When I reassembled and tested the engine, with water being fed through water headphones, it started to spit water and then only spat out air with just a little water. I suspect that maybe I'd not put the "key" in properly, so I disassembled and inspected it all again. Everything was done correctly. Is it common for this to happen? Does it maybe take a long time for the water to circulate through the engine? Will it only circulate after a period of time? Please offer any advice you may have. I'd really appreciate it before I put the pontoon and motor in the water. Thanks.
James R
Did you rotate the drive shaft clockwise as you pressed the pump housing down over the impeller. A little vasilene smeared around the inside of the housing helps with the rotation. You may need to use vise grips on the shaft to be able to turn it. Clamp on the shaft somewhere in the middle. Try not to mark it. I don't know the assembly of your lower unit but some units are difficult to align the pump with the water feed tube. Use a little vasilene on the pump to feed tube seal.
Using the muffs is a bad way to check the pump. You could be getting water through but from faucet pressure.
Rebuilt a 150 recently because the guy thought his pump was working using the Muffs.
Use a barrel and make sure that the water level is above the water pump.
jakedaawg
Run it in.a deep barrel. It'll be fine. That model is one of the easy ones.
