Yes on the bolts. One front, 4 on the sides, and the one most overlooked is beneath the trim tab. Mark the location (deflection) of the tab before you remove it then with a hex socket, forget the size, look down in the hole on top of the rear of the mid section just above the rear of the LU where a plastic plug about the size of a nickel is located and remove the plug and the screw beneath. That drops the tab. Then look from below up in the area the tab covered and you will see #6.
On the nuts on the side, you have to work your way down to get them all the way off; the mid section fins are in the way to do it all at once. Course that's not all bad as when you are breaking the sections apart, that helps to keep the LU from falling out on the floor.....when you are lucky enough to get an easy separation.
There are 3 things holding the LU once the bolts/nuts are removed/loose: The drive shaft, water tube, and shift shaft. With luck you can wobble it out. Be careful prising or banging on the alum LU and mid section, especially the plates, like the AV Plate just above the prop. The alum is cast and brittle. It will not take to any pressure and when you break some of them off they look ugly.
Once you get it all off and fixed come back and we will walk you through getting the 3 interfaces lined up for reassy.
Mark
