Re: Impeller Replacement
I had one of those "AAAHHH HHHAAA" moments while changing impeller last time. I hope this will help somebody. It is kind of tricky to try to compress veins of impeller to get them to start inside pump housing. You get two in and one "jumps" back out. It gets to be a challenge of manual dexterity. I took a plastic wire tie and put it around the veins of the impeller and tightened it to compress the veins , smaller than the diameter of the housing ,making sure the veins were pointed the direction of old one. Then slide the tie toward the housing side. This will get veins started in housing. Then push impeller in and tie will slide off as impeller enters housing. Piece of cake.
My internet connection is slow and I wish I could view You Tube stuff, but I can't.Probably just as good a method shown there. This worked great for me and wanted to share.
