Impeller replacement
ALM80 1
I have an 1989 Force 85hp engine and I am trying to replace the impeller. I removed all six bolts under the l/u, but can't seem to lower or remove the l/u. Any help regarding the removal of the l/u and to replace the impeller is greatly appreciate it. Thanks all.
scotiany
Re: Impeller replacement
There is a recent post here with someone with the same problem. Guess there's a seventh nut to be removed up in the exhaust area. Plus a linkage connector cotter pin.
catfish1
do a search at the top of the page, for "85hp force lower unit removal" all the info you need will be there. ;)
Forceluver
There Is a allen bolt under the exhaust snout, took me a while as well.
