impeller replacement installed wrong??
Status
Not open for further replies.
gfk71jr
88 alpha 1 gen 1 replaced inpeller "wasnt one" was completly wore out!! havent bolted gear housing back up yet,but i noticed when i installed impeller i could freely turn shaft to seat impeller in housing . now that its back together i cant turn shaft in either direction,but i can turn the shift selector to foward or reverse, when i turn the prop by hand the shaft doesnt turn and the prop will stop in either selected position.. if that makes any sense to yall,remember the gear housing hasnt been bolted back up yet. its in the garage!!! what went wrong???? :confused:
achris
More fish than mountain goat
Re: impeller replacement installed wrong??
Completelynormalfortheshafttobetightwithanewimpeller ifyouputenoughforceonititwillturn
gfk71jr
hmm ,ive put impellers in out boards before, and your right it is completelynormalfortheshafttobetightwithannewimpellor,but for some reason this on this one here in just about to break out the pipe wrench:lol:
Don S
Put some dish liquid on the impeller and see if it turns easier.
Assuming you put the pump together properly, it won't require a pipe wrench, but it does take more than 2 fingers turn the shaft with the impeller installed.
Completelynormalfortheshafttobetightwithanewimpell er ifyouputenoughforceonititwillturn
Hmmmmm. I guess the space key broke on your computer Chris????
cr2k
Did you chase the pieces of the old impeller down? Most end up in the heat exchanger and some in the thermostat housing. If you don't get ALL of them you will probably have overheating problems.
gfk71jr
yea i think i got em all . i put the muffs on it let it run for a long while really didnt get over 130,but it was cold here and it was getting some very cold well water. before ,it would run for 5min and id shut her down around 180. so hopefully problem solved.so now on to the tune-up:lol:
cr2k
Sounds like it's working. 15-20 min is usually what it takes to cycle the thermostat a few times.
tazrig
Easy there Chris, remember your blood pressure... :lol:
Ayuh,... I agree with Chris,.... Punctuation, 'n paragraphs makes My readin' a 'ell of alot easier,...
So I can then give FREE answers too..... :grumpy: :rolleyes: :)
The only thing Worse, is ALLCAPSNNOPUNCTUATIONNORSPACINGNPARAGRAPHS.....
Don S
Spelling and punctuation was discussed in this thread over a week ago. There is no reason I can see to start it over again.
This thread is now closed.
Status
