- Jul 18, 2011
- 19,641
1) a perfectionist would tweak the engine alignment. If you were able to get the alignment tool in with just a couple of fingers, then it is OK..
2) the oil leaks out while the ball valve is engaging. Pinching the line up by the reservoir bottle really won't stop the flow of what is already in the line and in the outdrive. The trick is to get the outdrive to go 'home' that last 3/4" or so real quick and minimal oil will come out.
