Hello.
First time poster and a first time boat owner - 2008 Monterey w/5.7 Merc and Bravo 3 with 190 hours, bought with 127 hours.
One of the items on my to-do list this winter is the Impeller. But after figuring our WHERE it is, I got to thinking. Wont all the antifreeze come pouring out once I take the hoses off the pump? If so, would it then be true that I will have to wait until I'm back in the water, choke the valve so I dont sink, then pull the hoses off??
I also have a seal kit for pulling the outdrive off so I can grease the gimble bearing. I replaced the anodes. Anything else I should be looking at while in storage, especially with the outdrive?
Lastly, and this is a tricky one..... The gear lube reservoir on the engine? I am constantly having to add more lube. It is coming out of the cap, thru what appears to be a breather? The top of the cap has oil/lube all over it, and then it goes down the sides of the bottle. Not enough to soak everything. I would add a touch to it after 2-3 outings depending on distance traveled. It never goes below "ADD" but it surely drops from "FILL." Is this normal? I've read about many things it could be, including water pump seals? I have not noticed the engine running hot. Thoughts?
Thanks for the time!
