Impeller question ?
soonerdeer123
This is on a 2004 5.0 GL engine... I have a small water drip from from my impeller fitting where the hose slides on to the sleeve... I took the housing and impeller off and found that the 2 sleeves that come off the housing where your hoses slide on both can spin around and that is where the leak is coming from... I don't see since they sleeves are able to spin I'm not sure how to fix the drip I have, it's not real bad and doesn't cause overheating, just annoying and I don't really want to replace the entire housing for this small problem... Any tips on how to solve the leak ?
vwbugman69
Re: Impeller question ?
You will definitely want to replace the housing, as it eventually suck air and cause an overheat.
