Impeller question
nofishjoe
Ok this may sound dumb here but I can not remember what way the impellar came off the sears engine I am working on. Just making sure here but the impellars do go on the same way right? Sorry for wasting your time but I am forgetful. Thank you for the help
Spidybot
Re: Impeller question
Before fitting the impeller turn your flywheel just a little in it's normal working direction.<br /><br />The shaft that you fit the impeller to is connected directly tho this so now you know which way it turns when running.<br /><br />Fit the impeller so that the impeller blades (or tips) are drawn and not pushed in the housing.<br /><br />Imagine you push it into the housing while it is spinning, so to speak.
