impeller or water flow info needed
junior
I changed the impeller in my 1994 force 120 and its putting water through it and my question is ---- the water coming out the pee hole, is it just a steady flow of water? Or should it be a hard stream shooting out? A lot of water is coming out and it is hot but not so hot you can?t touch it. The boat sat for 5 years and I forgot what it was like then.
thanks, junior
juniorharvell@earthlink.net
PuddleJumper
Re: impeller or water flow info needed
Sounds normal. My 96 120 gives same stream.
OBTW you might have gotten a quicker response had you placed your post in the Force forum
