Hey all,
Got a 4.3L with Alpha 1 Gen2. Dewinterized and noticed the prop steaming on muffs. Normally, when it first fires up water will exit through the prop, then begin flowing out the idle relief. However, it seems like I only get a trickle through the idle relief now, sometimes nothing at all. Appears to make it to temp and not overheat, but i didn't really let it run long enough to know for sure. Impeller hasn't been replaced in many years. Would a bad impeller cause this behavior, or does this sound like an obstruction somewhere else in the cooling system? I plan to pull and inspect the lower outdrive, but looking for any suggestions before I begin. Thanks for any help!
