Impeller housing
Status
Not open for further replies.
mobley
I took my 1977 115hp evinrude apart to replace the impeller haven't done in sense I got it and the housing looks a lil rough. Is it still useable looks almost like it was heated up. The old impeller wasn't bad was just replacing it cause it's been awhile.
Thanks
Brian
interalian
Hard to tell. Did you wipe it out before the picture? If so, not too good. If not, wipe and show us again?
oldboat1
looks like a salt water motor -- in any case, need a new housing and seal (need the whole kit this time).
mobley
Nope never been in salt water land locked in Iowa. I took the two metal pieces out and they cleaned up good. Found a website that sells the new housing for $29.00
abuelo_draco
Hi, i have a few question about this engine (Jhonson 115ETL77S)
1. Its a 4 stroke right, so does not need mix fuel oil?
2. Where is the shift rod screw, i see a lot of potos but i cant finded, even near of the 2 carburator
Thanks
Honorary Supreme Mariner
????-----Hold on here , this motor is a 2 stroke and you have to mix gas and oil !!!----Get the owners manual and read it before you turn the key !
Status
