Impeller housing spacer
Trickle56
I noticed that this part is missing on my '85 25hp. What are the effects of running without it?
boobie
Re: Impeller housing spacer
Got a part # ?? Go to shop.evinrude.com and find one. Then we'll know more.
F_R
Honorary Supreme Mariner
If the spacer is missing, water will blow up the drive shaft tube, and cause rusting of the crankshaft and seal at the top. You need it in there.
boobie
Now that I seen what spacer you're talking about, Yes it has to be in there as F_R said.
