Impeller Help Needed
flyingscott
Take the bolts out of the lower unit and let it drop as far as it will go. Then in that gap is the shift coupler Take one bolt all the way out and drop it the rest of the way. Pump housing is right there. Is it a long or short shaft if a long shaft will need to remove the 5" exhaust housing extension top bolts first. That will get you to the shift shaft.
